04' Ls 430 Center Console Removal
jpilk99
Hi folks.
I've seen pdf's and pictures before on how to take off the couple of pastic covers in the center console & shifter to be able to get down underneath to the audio wiring. I'm selling car and need to remove the DICE ipod adapter that's plugged in by the CD wiring. Any help is appreicated.
Thanks,
Jay
Here are instructions for the LS430 on Pro.Fit's website: http://www.pro-fit-intl.com/Adobe/MV-50-03-L-p18.pdf
The instructions are for installing one of their brackets but maybe it will be enough for you.
Thanks, but, I actually need help just getting the plastic cosmetic covers off of the shifter base and then that whole plastic cover underneath the shifter base - where the ashtray sits into. Any ideas? I've seen nice step-by-step photos but ofcourse can't find em' now :-).
Jay
Jay
Do these same instructions apply to a 1999 LS? If not, can someone post istructions for me? Much appreciated.......
Its probably easer on a 95-98 LS400. The provide website has instructions for the LS400 too: http://www.pro-fit-intl.com/Adobe/MV-50-03-L-p19.pdf
I've popped the radio in my 00 LS400 out a number of times -- takes about five minutes once you get the hang of it. After you remove the center air vents and the wood console/ashtray assembly, only four 10 mm bolts hold the radio/HVAC controls in place.
