thekidhartford Posted August 7, 2009 Share Posted August 7, 2009 Have a crazy idea to remove just the faceplate off a Naka and put it on my stock LS radio.......Anyone know if the faceplate can be removed? Is it a snap off, snap on type deal? Thanks tkh Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted August 7, 2009 Share Posted August 7, 2009 Kevin? Is that you from CL? The front of the Nak headunit isn't a snap-on faceplate -- I've had mine out several times. Besides, the button configuration of the 98-00 Nak and standard radio headunits is a little different. The Nak headunit doesn't have an ASL button or the ASL feature. It almost looks like the little buttons at the bottom are in a slightly different location too. Compare the photo of my Nak: http://us.lexusownersclub.com/forums/index...si&img=1349 with your Pioneer: http://us.lexusownersclub.com/forums/index...c=56051&hl= Is your radio "faceplate" damaged? With Nakamichi's getting difficult to get repair - parts not available - I'm wishing I had the standard Pioneer system. Quote Link to comment Share on other sites More sharing options...
dcfish Posted August 7, 2009 Share Posted August 7, 2009 If you need OEM audio/nav parts, I am always here B) Quote Link to comment Share on other sites More sharing options...
thekidhartford Posted August 7, 2009 Author Share Posted August 7, 2009 Kevin? Is that you from CL? The front of the Nak headunit isn't a snap-on faceplate -- I've had mine out several times. Besides, the button configuration of the 98-00 Nak and standard radio headunits is a little different. The Nak headunit doesn't have an ASL button or the ASL feature. It almost looks like the little buttons at the bottom are in a slightly different location too. Compare the photo of my Nak: http://us.lexusownersclub.com/forums/index...si&img=1349 with your Pioneer: http://us.lexusownersclub.com/forums/index...c=56051&hl= Is your radio "faceplate" damaged? With Nakamichi's getting difficult to get repair - parts not available - I'm wishing I had the standard Pioneer system. It is I.......I dabble in the lexusowners every once and awhile. How are you Jim! Trying to get the Naka style without the Naka stereo headaches like you said. I don't want the actual Naka stereo but I do want the faceplate so it looks like I have the Naka option on my car.....Crazy I know but I added wood steering wheel and shifter for cheap using car-part.com and thought if I could just snap off the faceplate on a broken Naka and fit it on mine I'd be good as gold, used Naka units go for $65 on car-part. That ASL button is USELESS!!!!! Looks like to me everything is lined up pretty well. How is it attached Jim? Thanks Quote Link to comment Share on other sites More sharing options...
thekidhartford Posted August 7, 2009 Author Share Posted August 7, 2009 If you need OEM audio/nav parts, I am always here B) dc, how is the radio faceplate attached on the 98-00 units? Is it screwed on or does it have some adhesive? thanks tkh Quote Link to comment Share on other sites More sharing options...
dcfish Posted August 7, 2009 Share Posted August 7, 2009 If you need OEM audio/nav parts, I am always here B) dc, how is the radio faceplate attached on the 98-00 units? Is it screwed on or does it have some adhesive? thanks tkh If my memory serves me correctly it is held in place with 4 screws and a ribbon connector which feeds the LCD. Quote Link to comment Share on other sites More sharing options...
