camlex Posted July 24, 2009 Share Posted July 24, 2009 Hello, My 97 ES300, I used Castrol 5W30 Synthetic Blend from day One. Due to rear main seal leak I am thinking to try Castrol High mileage 10W40. What you guys think, is it a good idea? My car has only 357,400. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted July 24, 2009 Share Posted July 24, 2009 I would be suprised if 10W40 would make a noticeable difference with the oil leak. My quess is that as hot as it is here in Tx, it would not hurt to try it this summer, but I would recomend swtiching back for the winter month! LoL Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted July 24, 2009 Share Posted July 24, 2009 How much to fix the rear main seal or how much longer do you plan to keept the car? The leak won't get any smaller with time & a slightyly thicker oil. Quote Link to comment Share on other sites More sharing options...
camlex Posted July 24, 2009 Author Share Posted July 24, 2009 $700, My mechanic saying it's not worth it. wait till trans. needs to change. Austin(UT) is taking my lots of money, I have to wait for next three years. No choice.. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted July 24, 2009 Share Posted July 24, 2009 Here's an inexpensive-it-might-work-fix. My 90 Nissan 300ZX developed a rear main seal leak about 10 years ago. Mind you, the leak was minor, leaving a 3 inch sized pool of oil under the bell housing after each run. It was suggested by an online forum to change the PCV valves on the car (that car had 2 of them), as their poor operation would cause increased crankcase pressure that would push oil past the rear main seal. I took the advice, changed the PCV valves, and the car has not leaked a drop to this day. Good Luck! Quote Link to comment Share on other sites More sharing options...
camlex Posted July 25, 2009 Author Share Posted July 25, 2009 I alredy tried that, yes it did help to slow down. Thank you for sharing. I just replaced oil with 10W40 High Mileage, Hope oil stop leaking. Thank you. Quote Link to comment Share on other sites More sharing options...
camlex Posted July 28, 2009 Author Share Posted July 28, 2009 I can't beleive this, let me confirm 100% but looks to me that oil leak is stop... Today I checked clamp which hold Cat. Conveter by main seal, it's dry. Quote Link to comment Share on other sites More sharing options...
