Blow Torch Posted July 2, 2009 Share Posted July 2, 2009 I searched in the old topics and found a few answers, but wanted to verify my findings I have a 90 LS400 and the speedometer is erratic. It will simply sit on zero for a while, then might register correctly for a few miles. then register 140mph :o When it is eratic, the cruise control does not work, but if it is accurate (rarely) it does I read that the speed sensors are prone to go bad, and found one (#89411-50010) for $72.00. Does this sound like what I need? Thanks Quote Link to comment Share on other sites More sharing options...
91LS400pilot Posted July 4, 2009 Share Posted July 4, 2009 I searched in the old topics and found a few answers, but wanted to verify my findingsI have a 90 LS400 and the speedometer is erratic. It will simply sit on zero for a while, then might register correctly for a few miles. then register 140mph :o When it is eratic, the cruise control does not work, but if it is accurate (rarely) it does I read that the speed sensors are prone to go bad, and found one (#89411-50010) for $72.00. Does this sound like what I need? Thanks Read this: http://www.clublexus.com/forums/ls400/2259...s-not-work.html Quote Link to comment Share on other sites More sharing options...
Blow Torch Posted July 5, 2009 Author Share Posted July 5, 2009 Thanks; I think I'm going to try the speed sensor Quote Link to comment Share on other sites More sharing options...
Quack11 Posted July 6, 2009 Share Posted July 6, 2009 I searched in the old topics and found a few answers, but wanted to verify my findingsI have a 90 LS400 and the speedometer is erratic. It will simply sit on zero for a while, then might register correctly for a few miles. then register 140mph :o When it is eratic, the cruise control does not work, but if it is accurate (rarely) it does I read that the speed sensors are prone to go bad, and found one (#89411-50010) for $72.00. Does this sound like what I need? Thanks Get under your car and check the wire harness from your xmsn (transmission) for frayed, chafed or anything that may interrupt the flow of current. The speed sensor should be the only component that is responsible for this issue if all other inspections are GTG. Let us know the outcome. Quote Link to comment Share on other sites More sharing options...
Blow Torch Posted July 11, 2009 Author Share Posted July 11, 2009 Update; Decided to spend the money on the sensor, once I checked for any wire (as best as I could see) fraying of cut/broken I purchased the 5S4770 sensor (this is the smaller one on the driver side) after verifying with Rockauto that it was the correct one. I replaced it this morning and it worked PERFECTLY for about one mile, then back to zero!!! I'm not really sure where to go from here. Although the car is in great shape, I can't justify paying a mechanic to diagnose and replace parts (Lexus parts) but the car is a PAIN to drive like this. Anyone know what I should do next Thanks Quote Link to comment Share on other sites More sharing options...
python Posted July 11, 2009 Share Posted July 11, 2009 jimlwalker@sbcglobal.net fire off an email to this guy, he is a guru on these things Quote Link to comment Share on other sites More sharing options...
