terrence Posted June 18, 2009 Share Posted June 18, 2009 Not only is my cd audio quality terrible, but at a certain volume the audio clips and cuts out. is it my head unit or the contacts from the cd to the amp. Anyone else having this problem? 1994 LS400 Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 18, 2009 Share Posted June 18, 2009 Not only is my cd audio quality terrible, but at a certain volume the audio clips and cuts out. is it my head unit or the contacts from the cd to the amp. Anyone else having this problem?1994 LS400 Sounds like the amp is bad. Quote Link to comment Share on other sites More sharing options...
terrence Posted June 18, 2009 Author Share Posted June 18, 2009 Not only is my cd audio quality terrible, but at a certain volume the audio clips and cuts out. is it my head unit or the contacts from the cd to the amp. Anyone else having this problem?1994 LS400 Sounds like the amp is bad. The radio is crystal clear though. Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 18, 2009 Share Posted June 18, 2009 Not only is my cd audio quality terrible, but at a certain volume the audio clips and cuts out. is it my head unit or the contacts from the cd to the amp. Anyone else having this problem?1994 LS400 Sounds like the amp is bad. The radio is crystal clear though. Run a cd cleaner a few times (the one with the brushes on the disc) clean the brushes between cleanings. ;) Then check the connections. Make sure the cd's are clean also. Quote Link to comment Share on other sites More sharing options...
terrence Posted June 18, 2009 Author Share Posted June 18, 2009 After a few too many minutes working on solving this issue, it seems that the factory installed car phone was the issue. to remove the phone ( and its negative affects like auto volume attenuation) just unplug the smallest wire plug from the back of the head unit. Then remove the fuse from under the steering fuse box to reset the stereo system. It figures, always look for simple solutions first. I actually found schematics for the amplifier and took it apart, assuming there was a beat capacitor or resistor somewhere. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 18, 2009 Share Posted June 18, 2009 After a few too many minutes working on solving this issue, it seems that the factory installed car phone was the issue. to remove the phone ( and its negative affects like auto volume attenuation) just unplug the smallest wire plug from the back of the head unit. Then remove the fuse from under the steering fuse box to reset the stereo system.It figures, always look for simple solutions first. I actually found schematics for the amplifier and took it apart, assuming there was a beat capacitor or resistor somewhere. That's odd. Audio system mute issues from the dealer installed car phones have usually affected the sound from the radio, cassette player and CD player equally -- at least that is what has been reported in previous threads. Usually disconnecting all the phone system components will resolve the problem -- on some Lexus phone systems, two connectors have to be plugged together after disconnecting them from the phone ECU in the trunk. Yours is the first time I've heard of anyone having to unplug a connector from the head unit to resolve this type of problem. To illustrate my point, several of us on this forum have attached the mute wire on aftermarket phone kits to a mute pin on the factory prewire phone harness -- when a call is in progress on on our aftermarket phone systems, the audio system is muted regardless of whether the radio, cassette or CD is in use. In case you don't already have it, attached is the full audio system diagram for a 1994 LS400 Nakamichi system. 1994_LS400_Nakamichi_diagram.pdf Quote Link to comment Share on other sites More sharing options...
terrence Posted June 19, 2009 Author Share Posted June 19, 2009 After a few too many minutes working on solving this issue, it seems that the factory installed car phone was the issue. to remove the phone ( and its negative affects like auto volume attenuation) just unplug the smallest wire plug from the back of the head unit. Then remove the fuse from under the steering fuse box to reset the stereo system.It figures, always look for simple solutions first. I actually found schematics for the amplifier and took it apart, assuming there was a beat capacitor or resistor somewhere. That's odd. Audio system mute issues from the dealer installed car phones have usually affected the sound from the radio, cassette player and CD player equally -- at least that is what has been reported in previous threads. Usually disconnecting all the phone system components will resolve the problem -- on some Lexus phone systems, two connectors have to be plugged together after disconnecting them from the phone ECU in the trunk. Yours is the first time I've heard of anyone having to unplug a connector from the head unit to resolve this type of problem. To illustrate my point, several of us on this forum have attached the mute wire on aftermarket phone kits to a mute pin on the factory prewire phone harness -- when a call is in progress on on our aftermarket phone systems, the audio system is muted regardless of whether the radio, cassette or CD is in use. In case you don't already have it, attached is the full audio system diagram for a 1994 LS400 Nakamichi system. Does anyone know the location in the vehicle of the car phone tranciever? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 19, 2009 Share Posted June 19, 2009 Does anyone know the location in the vehicle of the car phone tranciever? Here is a diagram showing the location of components: http://www.toyodiy.com/parts/p_U_1994_LEXU...EPGKA_8615.html Although the diagram sort of makes it look like the telephone ECU is in the car interior, it is really on the left side of the trunk behind the trim. Quote Link to comment Share on other sites More sharing options...
terrence Posted June 19, 2009 Author Share Posted June 19, 2009 Does anyone know the location in the vehicle of the car phone tranciever? Here is a diagram showing the location of components: http://www.toyodiy.com/parts/p_U_1994_LEXU...EPGKA_8615.html Although the diagram sort of makes it look like the telephone ECU is in the car interior, it is really on the left side of the trunk behind the trim. Im sorry but the link provided does not work, is there anywhere else to find this diagram? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 20, 2009 Share Posted June 20, 2009 Im sorry but the link provided does not work, is there anywhere else to find this diagram? Odd, the link works for me. I'll download and attach the diagram. Quote Link to comment Share on other sites More sharing options...
misslexus Posted January 30, 2013 Share Posted January 30, 2013 Does anyone have a video or instructions for the removal of the amp for a 94 LS400? Lexus has told me that it sits above the CD changer in my trunk. Any pointers on installing a replacement (used) amp? The P/N Lexus gave me was 86260-50110 but loo king at eBay, sometime PN 86280-50141 is given. Does anyone know which is correct or if either will work? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted January 31, 2013 Share Posted January 31, 2013 You can check the part numbers for the amps at http://www.toyodiy.com To be sure, get the exact part number you have now. Quote Link to comment Share on other sites More sharing options...
michaelsn Posted February 16, 2014 Share Posted February 16, 2014 1990LS400, Thank you. You have the correct diagram for my CD Changer. I was able to tap into the audio output and connect RCA cables. I now have a AUX line in and attached a Bluetooth adapter. Quote Link to comment Share on other sites More sharing options...
