Normal1 Posted June 6, 2009 Share Posted June 6, 2009 The water is getting in my 1998 LS400 trunk. every time I wash the car or it rains, I find a pond of water under the spare tire! I took everything out, and did a little test with a bucket of water, I found that the water is bypassing the rubber that prevent it and leak into the trunk at corner of the tail light that is attached to the trunk cover! I tried to move the rubber around to see if the water will leak from another corner, but it kept leaking form the same place!! any ideas! Thanks Quote Link to comment Share on other sites More sharing options...
curiousB Posted June 7, 2009 Share Posted June 7, 2009 This has come up a few times just search the forum and you'll find detailed instructions on how to fix this. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted June 7, 2009 Share Posted June 7, 2009 The water is getting in my 1998 LS400 trunk. every time I wash the car or it rains, I find a pond of water under the spare tire! I took everything out, and did a little test with a bucket of water, I found that the water is bypassing the rubber that prevent it and leak into the trunk at corner of the tail light that is attached to the trunk cover! I tried to move the rubber around to see if the water will leak from another corner, but it kept leaking form the same place!! any ideas! Thanks Here's a soluution posted by SK: http://us.lexusownersclub.com/forums/index...showtopic=57051 Quote Link to comment Share on other sites More sharing options...
