stroker Posted May 20, 2009 Share Posted May 20, 2009 Doing some simple maintenance on my 91 LS and need to know what I should use to clean the throttle body without damaging any sensitive parts inside it. Read about Throttle Body cleaner and MAF Sensor cleaner and all kinds of other cleaners but it just gets more confusing the more products I look at. Any suggestions would be greatly appreciated.. Thanks in advance, B. Quote Link to comment Share on other sites More sharing options...
killerFatty Posted May 20, 2009 Share Posted May 20, 2009 I used a can of carb cleaner from price chopper and had no problems. The results were great. I don't think it matters too much as long as you just spray the butterfly valves and not any of the electrical stuff. I don't see a need to spend a bunch of money on some fancy MAF cleaner. Just use Carb cleaner. If you were cleaning the MAF sensor though, I would be very carefull on what you select and how you apply it. All I did was sprazy the carb cleaner directly on my butterfly valve, let it sit for a couple minutes and scrub. I had about 2-3 mm thick of carbon build up, so it took a little elbow grease. Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 20, 2009 Share Posted May 20, 2009 Valvoline SYN stuff is sensor safe. That's what I used. Quote Link to comment Share on other sites More sharing options...
TexasLexus94 Posted May 21, 2009 Share Posted May 21, 2009 I cleaned the throttle body on my 94LS using carb cleaner, and a toothbrush duct-taped to a stick. Worked like a charm. Best of luck. Quote Link to comment Share on other sites More sharing options...
jsmith20 Posted May 25, 2009 Share Posted May 25, 2009 I thought the 2-3mm of crud was an exaggeration on earlier posts...but right on. I am 1/2 done on with cleaning my TB and intake manifold ('96 LS400). I could bare to try and clean out the intake mounted, so I'm taking it off and cleaning it, but a little more involved that I planned. The other component that was FILTHY was the EGRV valve assy. It took a little while to get it all of as it was pretty crusty, but now its nice and clean again...she is going to be breathing so much easier when its all back together :-) Quote Link to comment Share on other sites More sharing options...
Marklouis Posted May 27, 2009 Share Posted May 27, 2009 I thought the 2-3mm of crud was an exaggeration on earlier posts...but right on. I am 1/2 done on with cleaning my TB and intake manifold ('96 LS400). I could bare to try and clean out the intake mounted, so I'm taking it off and cleaning it, but a little more involved that I planned.The other component that was FILTHY was the EGRV valve assy. It took a little while to get it all of as it was pretty crusty, but now its nice and clean again...she is going to be breathing so much easier when its all back together :-) great job! feels great huh? :) Quote Link to comment Share on other sites More sharing options...
jsmith20 Posted May 27, 2009 Share Posted May 27, 2009 I thought the 2-3mm of crud was an exaggeration on earlier posts...but right on. I am 1/2 done on with cleaning my TB and intake manifold ('96 LS400). I could bare to try and clean out the intake mounted, so I'm taking it off and cleaning it, but a little more involved that I planned.The other component that was FILTHY was the EGRV valve assy. It took a little while to get it all of as it was pretty crusty, but now its nice and clean again...she is going to be breathing so much easier when its all back together :-) great job! feels great huh? :) It does...I also flushed the PS fluid, changed plugs and wires, and gave it an oil change! Not sure on the overall improvement, but your right, it feels great. I just got this car ('96 LS 400, 118k) and it is fun to see how its built. Has anyone had their switch bulbs burn out? I think the three in my heated seat and TRAC buttons are burned out as they don't light when my lights come on. The dealer quoted $12 ea, I was hoping something closer to $1.20 :-) Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 28, 2009 Share Posted May 28, 2009 The tiny bulbs are unfortunately spendy. Quote Link to comment Share on other sites More sharing options...
