1999 Gs 400
The GS has no accumulator. The system uses a receiver-drier, which performs a similar function. The desiccant material inside the receiver-dryer can be replaced. It is located in a long tube on the side of the condenser at the front of the car.
I have have been told the expansion tank is under dash in gs 400/99.
What do I have to take off to get to it and replace or clean it.
What is done when installing a new compressor.
arch
The expansion valve is under the dash, on the side of the evaporator core. It is difficult to get to without removing the entire dashboard. The only reason you would need to replace it when replacing the compressor is if the compressor had failed in a catastrophic way and contaminated the system with metal particles.
