f16amech Posted May 2, 2009 Author Posted May 2, 2009 is the overdrive button turned off? yes the overdrive button is on selecting overdrive to work at least the overdrive off light is not illuminated on the instrument panel and the light does work when selecting overdrive off and on.
95sc400nproud Posted May 3, 2009 Posted May 3, 2009 this could be one or more of 11 different things,... have the codes checked. REALLY, 11 different things. and thats JUST electrical, a few more mechanical!
dcfish Posted May 3, 2009 Posted May 3, 2009 anyone have suggestions is it electrical or what ? Maybe a solenoid ............ .02 cents
txn_2001 Posted May 15, 2009 Posted May 15, 2009 Your Engine Control Unit (ECU) or Speed sensor #1 bad or throttle position sensor. ECU is located under passenger feet and #1 sensor on transmission housing tail and throttle positon sensor on top of engine, throttle air intake.
