hello all, here recently i have noticed on acceleration the engine tends to bog down or stumble when the throttle is depressed about a third of the way. it is really noticeable after being at highway speeds then exiting and trying to accelerate from a near complete stop. i have repair manuals and i have checked the MAF, throttle body motor, and tps for resistance checks and they are good. there are no codes present. i dont have a lexus hand held tool, so a lot of the checks in the manual i can not do. does anyone have any thoughts? thanks in advance.
How many miles on the GS ? Have you ever cleaned the TB ? Check for any vaccum leaks, Does it idle normal ?
it has 134,000. i cleaned the tb when i installed the SRT intake and ecu about 10,000 miles ago; i hope that is not the problem. i haven't checked for vacuum leaks and it idles normally. i will check the vacuum leaks tonigt.
checked for any vacuum leaks, could not find anything.
Replace the maf.
thanks skp. replaced the maf. very little lag time and much better throttle response. :)
Replace the maf.
Hey whats the maf?
Mass air flow sensor B) It is located between the air intake filter and the throttle body, Can't miss it.............
