glenmore Posted April 16, 2009 Posted April 16, 2009 Anyone found a place where you can get this at a better price? Toyota dealer has it at list for $8.12/qt discounted to $7.15/qt.. Can any of the newer Dextron IVs be used? Thanks, glenmore 1990 LS400 1991 300CE 2000 C280
jeffls400 Posted April 16, 2009 Posted April 16, 2009 I saw a Toyota dealer on eBay selling for a decent price by the quart or case. I would stick to the Toyota T-IV, based on personal experience.
glenmore Posted April 16, 2009 Author Posted April 16, 2009 Thanks for the tip. I searched ebay turns out there is a specific Mobil #3309 ATF that can be used in Type IV applications. Check out this Mobil link: http://www.mobiloil.com/USA-English/MotorO...l_ATF_3309.aspx Now the trick is to find it cheap. Thanks, glenmore
Marklouis Posted April 16, 2009 Posted April 16, 2009 .....must....hold....back..... ....must......show.....restraint.......AAAAAAAARRRRRGH!!! ....whew... THAT was close.
jcrome04 Posted April 16, 2009 Posted April 16, 2009 .....must....hold....back.........must......show.....restraint.......AAAAAAAARRRRRGH!!! ....whew... THAT was close. "WHY DON'T YOU SEARCH n00b!!!!!" LOL Is that what you were going to say Mark???? hahaha Jk man! :D but yes the ONLY fluid to use is Toyota Type T-IV. Think about it this way.. Do you want to save yourself $50 NOW, Just to have tranny problems not too far down the road? Then you'll get stuck with a FAT bill to replace a tranny :D Spend a little extra now, and get it done proper. Don't skimp on it... but try to find the best price. Maybe contact Carson Toyota, or Parts.com Is there a part number for the Tranny Fluid? ?
jeffls400 Posted April 16, 2009 Posted April 16, 2009 Part number is 00279-000T4 for a case of 12 quarts and 00279-000T401 for a single quart. If you find the right dealer, you'll be pleasantly surprised at how inexpensive you can acquire the fluid for, so no reason to struggle to find the Mobil equivalent...it will not be any cheaper, as you can find a Toyota dealer willing to sell a case of Toyota T-IV for less than $44. Jeff
jcrome04 Posted April 17, 2009 Posted April 17, 2009 A case at Carson ~$48 http://www.trademotion.com/partlocator/ind...p;siteid=214915 Not showing up at Parts.com
Marklouis Posted April 17, 2009 Posted April 17, 2009 .....must....hold....back.........must......show.....restraint.......AAAAAAAARRRRRGH!!! ....whew... THAT was close. "WHY DON'T YOU SEARCH n00b!!!!!" LOL Is that what you were going to say Mark???? hahaha Jk man! :D ...yes...but i had to conjure up all the power i could muster to resist....so i formally apologize to those of you that experienced a blackout earlier... hope you find the deal you are looking for Glenmore :) we could all use a deal in these times.
glenmore Posted April 17, 2009 Author Posted April 17, 2009 "WHY DON'T YOU SEARCH n00b!!!!!"LOL Is that what you were going to say Mark???? hahaha Jk man! :D but yes the ONLY fluid to use is Toyota Type T-IV. Think about it this way.. Do you want to save yourself $50 NOW, Just to have tranny problems not too far down the road? Then you'll get stuck with a FAT bill to replace a tranny :D Spend a little extra now, and get it done proper. Don't skimp on it... but try to find the best price. Maybe contact Carson Toyota, or Parts.com Is there a part number for the Tranny Fluid? ? Just because you repeat something often enough doesn't make it so. All that does is prevent additional information from being learned. If you bother to go to the link, it is clear that Mobil 3309 ATF is OEM for our Lexus transmissions. That is good to know. It is even likely that Mobil is the manufacturer of Toyota Type IV. For practical purposes though, this doesn't really help because nobody seems to stock Mobil 3309. Ebay had some for about $5/qt. My local Lexus dealer ($72/case) was actually cheaper than the Toyota dealer ($86/case) for Type IV. Thanks all for the pointers to where to get it cheaper. glenmore 1990 LS400 1991 300CE 2000 C280
jcrome04 Posted April 17, 2009 Posted April 17, 2009 Dude... calm down... take a Zanex.... I was joking (if you couldn't tell) OEM Fluid for our earlier LS's was Toyota Type-II. Toyota Type T-IV has since replaced Type-II. And yes sir lots of different companies have their different equivalent of T-IV. . . . But at the end of the day, they are different enough to cause problems. Stay with Toyota Type T-IV
Marklouis Posted April 17, 2009 Posted April 17, 2009 ...its all in good spirit fellas...this is just such a controversial subject! I'm not knocking Mobile 3309 or any other knock off down....i just dont see it in my recomended fluid type in my manual is all... Im sure Mobile has probably R&D thier product to the specifications of the tranny they go into and placed the product strategically in the market to get a piece of the pie - and sure enough it does exactly what the label says it does...meets or exceeds the recomended etc. if its your preference...go for it! these LS's are way out of warranty anyways :P
glenmore Posted April 18, 2009 Author Posted April 18, 2009 Dude... calm down... take a Zanex.... I was joking (if you couldn't tell)OEM Fluid for our earlier LS's was Toyota Type-II. Toyota Type T-IV has since replaced Type-II. And yes sir lots of different companies have their different equivalent of T-IV. . . . But at the end of the day, they are different enough to cause problems. Stay with Toyota Type T-IV That's Xanax ..........................and I did .....................and I ................zzzzzzzzzzzZZZzzzzzzzzzzzzzZZzzzzzzzzzzzzz Thanks all, glenmore
jcrome04 Posted April 18, 2009 Posted April 18, 2009 Dude... calm down... take a Zanex.... I was joking (if you couldn't tell)OEM Fluid for our earlier LS's was Toyota Type-II. Toyota Type T-IV has since replaced Type-II. And yes sir lots of different companies have their different equivalent of T-IV. . . . But at the end of the day, they are different enough to cause problems. Stay with Toyota Type T-IV That's Xanax ..........................and I did .....................and I ................zzzzzzzzzzzZZZzzzzzzzzzzzzzZZzzzzzzzzzzzzz Thanks all, glenmore HAHAHA :lol: Touche my good sir
oldskewel Posted April 19, 2009 Posted April 19, 2009 Hi Glenmore, thanks for your excellent post a year or so ago on the engine mount replacement. It saved me a lot of time and made a hard job go smoothly. I wish more of the posts on this forum were as useful and well informed as that one. As far as I can tell, the Mobil 3309 is not just equivalent to the Type T-4, it is IDENTICAL to it. As in Mobil makes it and Toyota labels it at Toyota Type T-4 ATF. If you can't find the 3309, it doesn't really help though. Regarding buying a case of Type T-4 at Carson, it may not work. I tried to buy a case at Park Place Lexus (with free shipping due to the order being > $100) and was denied - they don't ship cases of ATF. I wish they would make it clearer on the website, but I guess some people order the parts and pick it up. I ended up calling around to the local Lexus and Toyota dealer, and got a case for a little less than $5/qt, after walking in to the Toyota dealer and asking for a discount for buying a case. So there's my tip/advice, hope it helps. It's only saving about $40 over full price, but it's always nice to pay less than full price for the best part.
jcrome04 Posted April 19, 2009 Posted April 19, 2009 As far as I can tell, the Mobil 3309 is not just equivalent to the Type T-4, it is IDENTICAL to it. As in Mobil makes it and Toyota labels it at Toyota Type T-4 ATF. If you can't find the 3309, it doesn't really help though. Where did you get this info?
glenmore Posted April 24, 2009 Author Posted April 24, 2009 I did some further searching and found this: http://www.volvoxc.com/forums/showthread.php?t=11368 Now I don't feel so bad. See how Volvo screws their loyal customers over the same thing! They also mentioned this topic being hashed over in the bobistheoilguy.com website. If you want to argue about oil, this is THE place. Thanks all, glenmore 1990 LS400 1991 300CE 2000 C280
jcrome04 Posted April 24, 2009 Posted April 24, 2009 Wow. That's actually some very interesting info.
Marklouis Posted April 24, 2009 Posted April 24, 2009 ...indeed interesting. i even read the Mobile 3309 .PDF on thier website - its seems specifically designed for the Aisin Transmissions... ...BUT! theres always a but around here :P i believe it still comes down to preference on what is most available, and how people feel about what product label they use in thier cars..even though its the same fluid. If i was driving a clunker, i would definately use a cheaper brand label if indeed it is the same stuff. but we are driving no clunkers my friend! i have to stick with what i know is a for sure thing, if Toyota slaps thier name on it - then i know for sure its good! Great research anyways!
17LexusOwner Posted April 25, 2009 Posted April 25, 2009 dear lord just go get some Oriely's Global ATF. It covers Toyota Type 4. I just replaced the tranny in my LS400 and used Global ATF and it's working fine. You can't tell a difference in shifting.
