SCRider Posted April 6, 2009 Share Posted April 6, 2009 Hello everyone I've been having this minor problem with the brake warning light inside the car. When I make a right turn nothing happens, however when I make left turns the light comes on then turns off. This has actually been happening for about 2 years. I change the pads when worn, got new calipers, and rotors seems to be fine. It's just that light problem, does anyone else have a clue? It's not a big deal because the car runs almost perfect, but I would like to know if I can rid of the problem if it's not a difficult solution. Thanks Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted April 6, 2009 Share Posted April 6, 2009 SCRider, Check the brake fluid reservoir, make sure it is up to the "MAX" line. I had the same problem a few years ago added some fluid and problem solved. Quote Link to comment Share on other sites More sharing options...
SCRider Posted April 7, 2009 Author Share Posted April 7, 2009 SCRider, Check the brake fluid reservoir, make sure it is up to the "MAX" line. I had the same problem a few years ago added some fluid and problem solved. Thanks I will give it a try Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 7, 2009 Share Posted April 7, 2009 Did you read the manual for what that light says? If so what does it indicate? Quote Link to comment Share on other sites More sharing options...
