Hello everyone I've been having this minor problem with the brake warning light inside the car. When I make a right turn nothing happens, however when I make left turns the light comes on then turns off. This has actually been happening for about 2 years. I change the pads when worn, got new calipers, and rotors seems to be fine. It's just that light problem, does anyone else have a clue? It's not a big deal because the car runs almost perfect, but I would like to know if I can rid of the problem if it's not a difficult solution. Thanks
SCRider, Check the brake fluid reservoir, make sure it is up to the "MAX" line. I had the same problem a few years ago added some fluid and problem solved.
Thanks I will give it a try
