lucerne Posted April 2, 2009 Share Posted April 2, 2009 recently my steering became tight as if the fluid was low but when i checked it was fine. Could the pump be bad anyway Quote Link to comment Share on other sites More sharing options...
killerFatty Posted April 2, 2009 Share Posted April 2, 2009 I recently had the same problem, but it was caused by the PS rack being replaced and it broke in in a few days. I don't think we have quite the same problem though, unless you recently replaced your rack & pinion. Sorry to not be of any help. Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted April 2, 2009 Share Posted April 2, 2009 It may not be the pump (yet). There is a solenoid on the rack underneath the car, it has a screen that may be clogged and needs to be cleaned. Unscrew it (fluid will flow out), and clean it with a brush. If it is clogged, pressure in the system will increase causing leaks. Do a search, many threads with instructions and pics, or click HERE Quote Link to comment Share on other sites More sharing options...
nc211 Posted April 2, 2009 Share Posted April 2, 2009 Ooops, posted this in the wrong thread earlier: Click here, start with page 5 and follow the pictures. I did this with my old LS, and it made a world of difference in the steering. I'm going to do it again soon to my GS430. http://us.lexusownersclub.com/forums/index...++screen++clean Quote Link to comment Share on other sites More sharing options...
jon65706 Posted April 8, 2009 Share Posted April 8, 2009 you should also check the pressure in your tires. Being 10-20 lbs low can cause your steerring to feel very boggy and tight too. Quote Link to comment Share on other sites More sharing options...
amcdonal86 Posted April 8, 2009 Share Posted April 8, 2009 10-20lbs low and I think he's notice much more than that! Quote Link to comment Share on other sites More sharing options...
