flipstyle808 Posted March 31, 2009 Author Posted March 31, 2009 so i could just buy the rims and slap it on? no mods needed?
PureDrifter Posted March 31, 2009 Posted March 31, 2009 so i could just buy the rims and slap it on?no mods needed? you will need the proper set of hubcentric centering rings since Nissan/Infiniti use a larger bore than toylex's ~60.1mm
jcrome04 Posted March 31, 2009 Posted March 31, 2009 so i could just buy the rims and slap it on?no mods needed? you will need the proper set of hubcentric centering rings since Nissan/Infiniti use a larger bore than toylex's ~60.1mm I second that motion.
PureDrifter Posted April 1, 2009 Posted April 1, 2009 Is This it? no idea, just tell the seller you need rings with the inside bore for your LS400 and the outside bore the same diameter as a G35/350z
