Would these Corvette wheels (C6 2005 and up) wheels fit a Lexus 1995 LS400? With some spacers and adapters?
Stok C6 wheel size?
Front Tire Size P245/40ZR18
18 x 8.5
Rear Tire Size P285/35ZR19
19 x 10
I would run 245 45 18 all around for the LS.
Generally try to stay away from spacers and adapters with the LS
The rear is a bit wide and unless it is the perfect offset it will rub on the fender or shock. 245 tires will be real hard to stretch as it is made for a 285 tire.
