frankmusic Posted February 22, 2009 Share Posted February 22, 2009 I'm one of the new guys on this forum. The stuff you can learn here is fantastic. :) I'm thinking of having my windows tinted. Summers in Florida can be tough on the interior and even worse if you are inside baking in it. I wanted to remove the high mount (3rd Brake) light from the rear shelf just before the tint installer does his thing. I had asked him about that and he said that he usually cuts around it. Well, I'm not particularly fond of that look so .......... Has anyone had the opportunity to (temporarily) remove the third brake light cowl on the IS250? Is it basically a lift straight up kind of thing? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
frankmusic Posted February 25, 2009 Author Share Posted February 25, 2009 Well, I think I may have found some useful diagrams that could be helpful when undertaking this task. ;) Quote Link to comment Share on other sites More sharing options...
frankmusic Posted February 25, 2009 Author Share Posted February 25, 2009 1. Remove Rear Seat Headrest. a - Disconnect the cable from the negative battery terminal. b - Remove the headrest from the center seat as well as the right and left seats. 2. Remove High Mounted Stop Lamp Set. a - Disengage the four tabs of the high mounted stop light set as shown in the illustration, and detach it from the package tray trim. (Fig. 2-1) b - Disconnect the connector and remove the high mounted stop light set. Quote Link to comment Share on other sites More sharing options...
frankmusic Posted February 25, 2009 Author Share Posted February 25, 2009 3. Remove High Mounted Stop Light Unit. a - Remove the EPT sealant from the high mounted stop light cover as shown in the illustration. (Fig. 3-1) b - Extend the ribs of the high mounted stop light cover in the direction of the arrows as shown in the illustration, disengage the two tabs, and remove the high mounted stop light unit. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted February 25, 2009 Share Posted February 25, 2009 If you have a tinter that's worth anything, He can tint the entire rear window and you don't have to remove the third brake light at all. I had my windows tinted and they didn't have to remove anything. Quote Link to comment Share on other sites More sharing options...
