03 Ls430 A/c Filter Help
lil baby
If it's anything like the UCF20 LS400, look in your owners manual. Basically, open the glovebox, remove the little cut-out panel, and that should give you pretty much direct access to the A/C filter.
lil;
If you follow the instructions above, You will find that after having done it once, "yes it is a bit goofy, but yes, it is very simple". It's one of those subjects/fixes that looks a lot more complicated than what it really is.
Consider buying a good HEPA furnace filter ($12), cutting pieces (equivalent of about $ 3.00) out of it & re-fitting a piece where the old filter was. It works fine, I've been doing it for years. The biggest benefit I've found ( besides cost) is higher airflow & colder A/C. The aftermarket replacements are about $ 18.00 & genuine Lexus are about $ 35.00. Conversely, some people don't like the hassle & just buy the aftermarket filter.
