hi everyone. i just removed my center armrest to run rca and remote wires to my trunk. now when i drive at night with my lights on the trans shift lights do not work. none. i can still shift normally but the lights do not illuminate. also on the dash when the car is in either park or drive the other light is on. i.e. when in park the drive light shows on the dash and when in drive the park light shows. i just took everything apart again to check and make sure everything was connected correctly and it is. what could be causing this? has anyone expirenced this before? thanks for any help
It's hard to help a person that doesn't give the model year of his car. Would you put it in the "Car Model" field in your profile or in a signature?
I'll randomly assume you have a 1990 LS400. Here is a link to a diagram of the shifer assembly: http://www.toyodiy.com/parts/p_U_1990_LEXU...EPGKA_8410.html
I'm guessing that you knocked something loose when you ran your wires,
