bjayhova Posted January 30, 2009 Share Posted January 30, 2009 I HAVE 2 MORE TRIES I MISPLACED THE CODE...I JUST SWITCHED THE BATTERY AND NOW MY RADIO SAYS "SEC" DO YOU KNOW WHERE I CAN FIND IT Quote Link to comment Share on other sites More sharing options...
Lexucan Posted January 31, 2009 Share Posted January 31, 2009 The code is user definable, meaning whatever 3 digits the original owner selected are the only digits that will work to unlock the radio. I don't know what the default code is as set by the factory, but if you use up all of your 10 tries, then you'll have to take your car to a Lexus dealership where they will reset the code so that you can use your radio again. I'm not sure how much that costs, but you can probably be sure it's not cheap. :( Good luck. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted January 31, 2009 Share Posted January 31, 2009 I don't know what the default code is as set by the factory A default security code was not set at the factory for the LS400 I bought new in 1990 so I doubt if it was for your ES. I think I remember people on Lexus forums saying that dealers charged them $50 to $100 to unlock the radio. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted February 3, 2009 Share Posted February 3, 2009 I believe I read somewhere that the dealer has to pull the radio from the dash to see the label on the radio's rear panel. It lists the radio's serial number, etc., which allows them to search the radio manufacturer's lists for the default codes to unlock the radio. Someone correct me if I'm wrong. Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 3, 2009 Share Posted February 3, 2009 It could be the last 3 digits of the vin # or the last 3 digits of the key code. Quote Link to comment Share on other sites More sharing options...
