Bigdogchief Posted January 18, 2009 Share Posted January 18, 2009 After i changed the battery in my 2004 rx330 the sunroof switch that opens and closes it now also tilts the sunroof. It is hard to close b/c you cannot tell if it is tilted because the auto close does not work, you need to hold the switch to close it. The tilt button now tilts and opens the sunroof also. Another problem is you cannot control the other windows from the drivers seat anymore. Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted January 18, 2009 Share Posted January 18, 2009 Check your Owner's Manual, Hoss. There is a reset procedure for the windows and sunroof that you need to follow after a battery replacement. It is in the book. Good Luck! Quote Link to comment Share on other sites More sharing options...
NetSurfer Posted January 29, 2009 Share Posted January 29, 2009 Check your Owner's Manual, Hoss.There is a reset procedure for the windows and sunroof that you need to follow after a battery replacement. It is in the book. Good Luck! I had the same problem, didn't read the manual, and thanks to your tip. Now it works. Thanks again. Quote Link to comment Share on other sites More sharing options...
suarezja75 Posted March 26, 2009 Share Posted March 26, 2009 My RX330 didn't come with the manual. Have one on the way from Lexus but they said it would be 7 weeks and I want to try and fix this sunroof before I get rained on. Stupid battery. Quote Link to comment Share on other sites More sharing options...
Deepak Gandhi Posted March 9, 2010 Share Posted March 9, 2010 I checked the book but could not find the reset procedure for mon roof on page 130, 132. Can you help? Hat page please? Or any other place you might know? Deepak Check your Owner's Manual, Hoss.There is a reset procedure for the windows and sunroof that you need to follow after a battery replacement. It is in the book. Good Luck! Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted March 9, 2010 Share Posted March 9, 2010 I checked the book but could not find the reset procedure for mon roof on page 130, 132. Can you help? Hat page please? Or any other place you might know?Deepak Check your Owner's Manual, Hoss.There is a reset procedure for the windows and sunroof that you need to follow after a battery replacement. It is in the book. Good Luck! Going from memory so I may be wrong...but I think that you just hold back the button as you are opening the sunroof all of the way. Then it should go the whole way back and then return to the close position. Keep holding the button...once this is done it should be complete. I think that is how it is done...maybe some other experts can chime in. Good luck Quote Link to comment Share on other sites More sharing options...
code58 Posted March 11, 2010 Share Posted March 11, 2010 Going from memory so I may be wrong...but I think that you just hold back the button as you are opening the sunroof all of the way. Then it should go the whole way back and then return to the close position. Keep holding the button...once this is done it should be complete. I think that is how it is done...maybe some other experts can chime in. Good luck I believe to hold the button for just a few seconds after the windows or sunroof are cycled is indeed the reset procedure Quote Link to comment Share on other sites More sharing options...
lexus114 Posted March 18, 2010 Share Posted March 18, 2010 Going from memory so I may be wrong...but I think that you just hold back the button as you are opening the sunroof all of the way. Then it should go the whole way back and then return to the close position. Keep holding the button...once this is done it should be complete. I think that is how it is done...maybe some other experts can chime in. Good luck I believe to hold the button for just a few seconds after the windows or sunroof are cycled is indeed the reset procedure I just did this today because it was not automaticly stopping when in closed position. Turn your key on,press and hold the tilt switch. The moon roof will tilt up,close,open all the way,and then close all the way at which point you release the switch and your finished.Its called the initial programing process or something. Quote Link to comment Share on other sites More sharing options...
