eagle-7 Posted January 10, 2009 Share Posted January 10, 2009 Hi, The battery on my wife's 07 RX350 was replaced in late November. She was advised to drive it regularly so as not to run it down due to inactivity. Knowing she'd be out of town for a month, we figured we'd just disconnect the battery like we'd done with our other cars. (Negative post was disconnected) She connected the battery today and it started just fine. She had to reset the seats, radio, steering column, etc. She noticed that the only the driver side window goes up and down. None of the other three windows work. She hasn't checked the moonroof. She also noticed that when you turn off the car, it sounds almost like a jet engine that whines/winds down vs. a simple quick engine cutoff. Questions: - Is there a reset for the windows? - Is the whining wind down sound the engine makes upon turning it off require some sort of a "reset" also? Done by the dealer perhaps? Your help would be appreciated. Thanks, eagle-7 Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted January 10, 2009 Share Posted January 10, 2009 Your owner's manual has the procedure for resetting the windows and sunroof. Be sure that the window lockout is not engaged on the driver window control pod Quote Link to comment Share on other sites More sharing options...
eagle-7 Posted January 11, 2009 Author Share Posted January 11, 2009 Thanks. Going to each window and running a cycle of up and down and holding the button a few seconds longer after it is all the way up worked. r, eagle-7 Quote Link to comment Share on other sites More sharing options...
