Climate - Outside Temp
bainzey
Hi,
I reside in Canada and have a US import RX 330. Since I am in Canada I wanted to switch some of the default settings to be applicable to Canada. IE: default GPS zone, instead of miles use KMs during distance calculations, and Degrees Fahrenheit to Degrees Celsius.
Well the first two aren't that hard to do. But is there any way to switch the default temperature unit, as it remains in Degrees Fahrenheit, and I can't seem to see an obvious spot to change this.
Can this be done via one of the hack menus perhaps? Any help or direction is appreciated.
Cheers
Anybody?!?!!?
I'm sure one of you exerienced Lexus owners has some idea... :geek:
Search the manual. I remember reading something in there how to do it - you are supposed to hold one or two buttons for 3 seconds or something like that. My car is in the shop right now so I can't look it up at the moment.
  • 3 weeks later...
I know how to change
miles to km/h
km/h to miles
F to C
C to F
RX300
RX330
RX350
Gregor001 B)
Care to Share?? Why the secrecy?
because I must modify instrument cluster data
Regarding Gregor's information ...
There has long been a thriving industry in Europe for modifying vehicles from miles/Fahrenheit to km/Celsius. Most every European employee who worked on temporary assignment at our location here in Kansas bought a U.S. spec vehicle and had it shipped back home and modified. There are companies in Canada that modify everything from miles/Fahrenheit to km/Celsius.
  • 2 years later...
Anybody?!?!!?
Fredster,
Could you check with your mechanic about how to change F to C and Miles to Kilometers? Or do you remember which buttons to push?? THANKS IN ADVANCE!
