LeeC81 Posted November 8, 2008 Share Posted November 8, 2008 When i changed my oil today and replace the filter; i was checking the sterring fluid as well as the brake fluid. Apparently the steering fluid should look red right?, but mine has a dirty brown colouring. As for the brake fluid, it is looking not too healthy either. anyone know how to flush them out, and replace them with new fluids? I have an 02 gs300; thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
LeeC81 Posted November 11, 2008 Author Share Posted November 11, 2008 When i changed my oil today and replace the filter; i was checking the sterring fluid as well as the brake fluid. Apparently the steering fluid should look red right?, but mine has a dirty brown colouring. As for the brake fluid, it is looking not too healthy either. anyone know how to flush them out, and replace them with new fluids? I have an 02 gs300; thanks for the help guys. anyone can help? Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted November 14, 2008 Share Posted November 14, 2008 The easiest way to do the steering fluid is the syphon out the old fluid, top it off with new DexIII transmission fluid, start the car, let it circulate... and repeat a few times. This is not the most efficient method, but it is the easiest. I used Mobil1 synthetic ATF in my power steering system. As far as the brake fluid goes you'll need to bleed your brakes. There are plenty of DIY post on this forum and clublexus.com Quote Link to comment Share on other sites More sharing options...
sakataj Posted November 14, 2008 Share Posted November 14, 2008 The easiest way to do the steering fluid is the syphon out the old fluid, top it off with new DexIII transmission fluid, start the car, let it circulate... and repeat a few times. This is not the most efficient method, but it is the easiest. I used Mobil1 synthetic ATF in my power steering system. As far as the brake fluid goes you'll need to bleed your brakes. There are plenty of DIY post on this forum and clublexus.com ok so bythebay doesnt think im always bashing him, which im not i was just being stubborn and arguing a point.......(you'll see when u read the post) i would suggest you try this for your power steering...... http://us.lexusownersclub.com/forums/index...showtopic=52270 Quote Link to comment Share on other sites More sharing options...
