pdiddy594 Posted October 10, 2008 Share Posted October 10, 2008 I have a 03 gs430 w/ Nav and wanted to know how much space is available for a new replacement sub to fit in the factory location? I want to use a Image Dynamic Max sub but need to know how much room I have to work with! Moreover what impedance is required to work off the factory amp and how much power does the factory amp supply? Thanks for any responses! ;) Quote Link to comment Share on other sites More sharing options...
pdiddy594 Posted October 10, 2008 Author Share Posted October 10, 2008 I have a 03 gs430 w/ Nav and wanted to know how much space is available for a new replacement sub to fit in the factory location?I want to use a Image Dynamic Max sub but need to know how much room I have to work with! Moreover what impedance is required to work off the factory amp and how much power does the factory amp supply? Thanks for any responses! ;) I did some research and did find out that there is 8 inches of depth to install a aftermarket sub in the stock location! Now I need to know do I use dual 4 ohm or 2 ohm? Something tells me dual 4 ohm! Quote Link to comment Share on other sites More sharing options...
mlgs300 Posted October 17, 2008 Share Posted October 17, 2008 What's wrong with the factory stereo? Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted October 19, 2008 Share Posted October 19, 2008 I'm not sure if you can power an aftermarket sub with the stock ML amp and get good results... you'll probably be better off adding a second amp... also are those subs free air subs? or would you be setting it up in some type of enclosure? Quote Link to comment Share on other sites More sharing options...
