buckeyemike Posted September 23, 2008 Share Posted September 23, 2008 I was just informed that my 2004 Lexus RX330 needs new front struts, insulators and supports to the tune of $1,300. Has anyone replaced these themselves? I am somewhat mechanically inclined and am wondering if I should bend over or try it myself. The Toyota dealer said the parts cost $700.00. Any help would really be appreciated. Thanx, Mike Quote Link to comment Share on other sites More sharing options...
Mike Bearden Posted October 2, 2008 Share Posted October 2, 2008 I was just informed that my 2004 Lexus RX330 needs new front struts, insulators and supports to the tune of $1,300. Has anyone replaced these themselves? I am somewhat mechanically inclined and am wondering if I should bend over or try it myself. The Toyota dealer said the parts cost $700.00. Any help would really be appreciated.Thanx, Mike I am not too sure about that price (sounds high) but replacing the struts on any car isn't a simple or easy job. Check with an independent shop. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted October 2, 2008 Share Posted October 2, 2008 It's easy. Do it yourself. the only special tool you will need is a spring pretensioner that you can get as a loaner from any Auto Zone or Pep Boys. I would check Sewell Lexus for parts prices. 2004 RX 330 suspension components But before you go that far, it's a 2004 and you need front suspension work? That seems a bit overstated? Do you have some really rough road conditions there? Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted October 3, 2008 Share Posted October 3, 2008 I'm about to tackle this job myself on my '99 RX300. I've already had the struts out a while ago to replace the mounts. It's not that difficult of a job. As Smooth said, you need a spring compressor, but you also need either a nice breaker-bar or impact wrench to get the lower bolts/nuts off the strut. From there it's just time and energy to do the replacement. I'm just doing my rear struts, and I figure I'll have the job done easily in a 1/2 day. Struts were about $120/each, mounts about $40/each, insulator rings about $12/each... doing the job without paying outrageous labor fees, ..."priceless" Oh yeah, be sure to get an alignment after strut removal/adjustment/replacement. Quote Link to comment Share on other sites More sharing options...
