Shift Led's Not Working-
Hello,
I've got a 99 GS300 and the other night I noticed that the shift plate LED's do not light up anymore. Has anyone out there had the same problem? I'm hoping that it's just a connector that's loose, I'm going to take apart the center console and see if there's a loose connection.
Thank you,
AL
Remove the ashtray. Lift the rear edge of the wood trim around the shiftgate and unplug all the switches. Remove the wood trim. Under the shiftgate you will find the burned out bulb.
Thank you ! I will take it apart this weekend... Is it an actual bulb that can be replaced or a LED that is not replaceable ?
