theoldpaths Posted September 15, 2008 Share Posted September 15, 2008 I have a 90' LS400 that loses speaker volume when it is rainy outside. I can turn the volume all the way up and can just barley hear it. It doesn't mater if I'm listening to the radio or CD, same problem. I think opening and closing trunk helped at one point. My wife was in the car, and as I open and closed the trunk, she said it got better for a second. I don't think I have ever had this happen on a dry day. Any ideas? Thank you Quote Link to comment Share on other sites More sharing options...
ed lexus Posted December 30, 2008 Share Posted December 30, 2008 I have same problem with my 1992 LS400. When it rains I lose sound. I have to wait for weeks sometime to get sound back or for Cold / freezing days. No one has been able to resolve this issue for me..... Quote Link to comment Share on other sites More sharing options...
don corleone Posted December 30, 2008 Share Posted December 30, 2008 are you guys using the factory head unit. this might be the issue. i remember once i left my sun roof open while shopping. it rained very hard while i was in the store and my whole inside was soaked. i had to drive around and let the heat of the engine dry the internals of the radio. while it was broken the sound was barely above a whisper. even all the way up. there might be something wrong with the head unit or you might have a leaking sunroof which is causing moisture to build up in the cabin. if the trunk affects the sound it may have to do with the trunk wiring hinge. do a search because this is a common issue with 1st gens. Quote Link to comment Share on other sites More sharing options...
