GliTCH Posted September 8, 2008 Share Posted September 8, 2008 Edit: I apologize for the lengthy post, but this is a very strange problem that I have logged in complete detail which may be helpful for others who have the same issue. (Hours of Google and forum searches have shown it's a common problem for older SCs). About a week and a half ago my oil pressure light started coming on intermittently. This has usually been happening for me right around the time I need to get an oil change and then the light stays off for about another 3,000 miles or so. Anyway, I'm not even sure this is worth mentioning because my real problem is this: A week ago I decided to check the oil before a quick 100 mile trip. I stopped at a gas station, checked the oil and it was a little low so I added a half a quart. I don't know if this is worth mentioning but I didn't have a funnel at the time, and I was very tired, very wired and I did get about a capfull or so of excess oil around the oil filler cap which proceeded to work its way down onto the engine's surface. Some of it seeped into the black plastic strip that covers the 1UZ's plugs and wires on that cylinder bank. I know from previous experience that liquids don't really leave that area too fast because the area above a spark plug is kind of like a well that, after washing your engine bay (don't do it) or spilling a little oil, will tend to sit there. Anyways, I'm digressing here. After adding a half a quart, I get in the car, try to start it, and it won't start. The engine cranks over great but will absolutely not fire. I get on the phone with a towing company for about 20 minutes, then after I get off I try the car again and it starts up. Thinking that maybe the problem had fixed itself I went on my way. I notice that the oil pressure light is off and has not come back since (even till now). Most of the night went without incident. I made the trip up, parked my car in front of a friend's house for a couple of hours. We left and went to meet up with some other people in another part of town, about a 15 minute drive. After staying over there for an hour, it was time to come home. At 3AM, with everyone on location already passed out, I get in the car, try to start it and it won't start. Same as before. Cranks over but doesn't fire. I try to catch some Zzz's out back by the pool to prepare to deal with it in the morning. It's now 6AM. Sleeping out back by a pool on a summer night in Florida, on cheap outdoor furniture really isn't fun at all. I start feeling more compassion towards homeless people. Tired, wired, and needing to be in at work in a little under 5 hours with a 1 hour ride back home, I get in aaand.. what the hell, the SC fires right up. I drive for 5 minutes and stop to fill up before getting on the highway. No problems starting up the car again to get home. I researched the issue and while I did find several references to plugs, cables, and so on, the one problem that seemed to really fit the bill was the fuel pump ECU. After doing some basic things first like checking the air filter and fuses, unplugging and replugging cables and checking vaccum hoses and so on, and still seeing the same problem (starts fine while cold / cool, will not start while warm / hot) I decided to get a fuel pump ECU. I found one on eBay from a salvage company for 90 bucks, got it shipped for the crappiest shipping ever and it just came in about 4 hours ago. So I switch it out, real easy job, took only 10 minutes.... start the car, it starts up. I smell gas while backing out of the driveway. Okay, no big deal, the engine is running rich because it needs to warm up. So far so good. I take it out for a drive, gentle at first and getting a little more aggressive as the car warms up. My goal is obviously to make sure that this really did fix the problem and to see whether or not, after driving it for a while, I can start it up again while the engine's hot. I notice that the engine is actually smoother now, or maybe I'm just imagining it? Shifts feel smoother and quicker than I remember, or maybe it was not driving my car for 5 days (and driving a loaner Saturn with no power anything, even steering, that made me have a newfound appreciation for my SC). Either way, I start having a good feeling about it, till, inevitably, I take it back home after a 15 minute drive. I have a Viper alarm on the SC that has been on there since I got it 3 years ago, and it has remote start. While the key is in the ignition, I can hit a button on the remote to keep the engine running even if I take the key out. So I do exactly that, just to let the car cool down while running instead of shutting it off abruptly. I get out of the car and sit in my garage looking at it as it's parked in the driveway, and I notice that there is faint white smoke coming out of the bottom of the car along the passenger side. I'm not sure if it was wafting backwards from the engine bay and out the side, or wafting forwards from the exhaust pipe and out the side.. but either way I kill the engine and let it sit for a few minutes. The smell isn't straight gas but it definitely has a hint of gasoline in it. I try to start the car, and it's the same issue. Cranks but won't fire. During the run with the new fuel pump ECU I had no idle issues, no jerking, no power loss, no ignition timing, or any other performance issues. There are no diagnostic lights indicating a problem. The oil pressure light doesn't come on. I am due for an oil change but since I don't feel safe getting under the car while it's on jackstands and I really don't want to chance being stuck at a Jiffy Lube for 6 hours, I wanted to know if there was something else I could check for from here before attempting the obvious. Given what I've experienced, do you think this is an electrical/electronic issue or a mechanical issue? Could something like a simple oil filter / fuel filter change fix the SC400 not starting up while the engine is hot? Quote Link to comment Share on other sites More sharing options...
GliTCH Posted September 9, 2008 Author Share Posted September 9, 2008 Update: Got an oil flush, filter change, and had them fill it with Pennzoil 5W30 synthetic. I also got a new cheap paper air filter (as a backup until I get he filter cleaner to clean my dirty reusable K&N). But after doing just that basic maintenance the car appears to start fine when warm now. As soon as I got it back after the oil change I took it out for another spin, warmed up the engine, then raced it for a bit, then brought her back home. Killed the engine, waited a minute, started it and it started up. I could hardly ****ing believe it. In fact, I didn't, so I killed the engine, waited another minute, then started it up again, and I let the remote start shut it off after 15 minutes. Waited 5 minutes, started it, and it started. At that point, I started feeling a lot better about the car, even though I still, till this second, am extremely skeptical as to how a simple oil and filter change could fix what definitely appeared to be a complex problem that involved engine management and signaling. Just before starting this post, I started the car up for a third time, let it run through the 15 minute timer, then waited a minute and sure enough, as of a few minutes ago it started up fine. I'm extremely confused, still somewhat skeptical, just a bit paranoid and still wondering if there's something else I should be checking for given the history of the issue and the steps I've taken. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted September 9, 2008 Share Posted September 9, 2008 sounds like the Dirty Filter might have been the culprit. Any chance the Tech added something else? Quote Link to comment Share on other sites More sharing options...
rekit Posted September 12, 2008 Share Posted September 12, 2008 I've got no answer, but that's some excellent writing! Really, it's like an English lesson! Good luck with your problem. Quote Link to comment Share on other sites More sharing options...
GliTCH Posted September 23, 2008 Author Share Posted September 23, 2008 As it turns out, that wasn't the problem. I took my car in to Wilde Lexus of Sarasota, they called me the other day citing a starter issue. Really? I find that a little hard to believe, it doesn't sound like the starter is having any issues at all when I crank the engine about 50 times in the 5 hours it takes for me to start it up. Any last ideas? If I don't get anything definitive I'm going to probably end up parting the car out. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted September 23, 2008 Share Posted September 23, 2008 Ignition coils? didn't you replace the starter already? Give it a shot if you haven't already. you could ask the dealer to do so, and if they can't fix it complain and get your money back. Before you part it, shoot an email to JP importz, and ask for the owner(i forgot his name) http://planolexusservice.com/PageView.aspx?PageID=1 Let him know that you're a LOC member and you're exhausted all avenues and need some advise. Quote Link to comment Share on other sites More sharing options...
sonnyg22 Posted September 25, 2008 Share Posted September 25, 2008 Ignition coils? didn't you replace the starter already? Give it a shot if you haven't already. you could ask the dealer to do so, and if they can't fix it complain and get your money back.Before you part it, shoot an email to JP importz, and ask for the owner(i forgot his name) http://planolexusservice.com/PageView.aspx?PageID=1 Let him know that you're a LOC member and you're exhausted all avenues and need some advise. Hi, I'm having the same exact issue!!! Very frustrating. The car usually starts when cold and runs great..but when it's warm it is difficult to start, but once it does start it runs great even with the engine warm. Can you instruct me how to replace fuel pump? Any other advice would be greatly appreciated before I take it to the dealer and get ripped!!! Thanks! Sonny Quote Link to comment Share on other sites More sharing options...
UCF3 Posted September 26, 2008 Share Posted September 26, 2008 Are you sure it's the Fuel Pump and not the filter? What have you done so far? Quote Link to comment Share on other sites More sharing options...
sonnyg22 Posted September 26, 2008 Share Posted September 26, 2008 Are you sure it's the Fuel Pump and not the filter? What have you done so far? I haven't done anything yet. I purchased a fuel filter from Kragen and had a buddy who is somewhat mechanically inclined take a look at it up on a hoist. We located the fuel filter behind the rear driver side tire, but it was very difficult to take off and he didn't want to strip it. We also decided not to go any further because the parts person at the local lexus dealership here in Fresno,ca asked me why I was replacing the fuel filter on this car when I called to get a price. She stated that fuel filters are very rarely replaced on this vehicle. Any suggestions??? Please refer to my previous posts under my member name to understand the issue I'm having. Thanks! Quote Link to comment Share on other sites More sharing options...
GliTCH Posted November 30, 2008 Author Share Posted November 30, 2008 Well, I haven't given up on this car yet. I will figure this out if I have to tear every single part out of it. The good news is I did buy a 2007 IS 250 in the meantime, after renting cars for 2 months at about a grand a month. So that's my daily driver and, just like that, my SC is now a project car. Quote Link to comment Share on other sites More sharing options...
GliTCH Posted January 10, 2009 Author Share Posted January 10, 2009 I figured this out, by the way. After buying my new IS 250 I kept my SC and had some friends look at it. Believe it or not the issue is with the alternator, it's slowly failing and it won't keep the battery fully charged. The battery will have enough juice to start the SC before a long drive, after that drive there aren't enough CAs to turn the engine over quick enough. You can test this by jumping the battery with another car that's large enough. What happens when you let the car sit to "cool down" is the battery gains just enough of a charge to crank the engine and fire the cylinders. The deterioration of the alternator is still TBD. I believe it may be because the power steering pump is slowly starting to leak PS fluid on it again, which is a common problem with older SCs. Quote Link to comment Share on other sites More sharing options...
snakescoupe400 Posted January 13, 2009 Share Posted January 13, 2009 Ahh lol. Quote Link to comment Share on other sites More sharing options...
Aggie Posted January 27, 2009 Share Posted January 27, 2009 Edit: I apologize for the lengthy post, but this is a very strange problem that I have logged in complete detail which may be helpful for others who have the same issue. (Hours of Google and forum searches have shown it's a common problem for older SCs).About a week and a half ago my oil pressure light started coming on intermittently. This has usually been happening for me right around the time I need to get an oil change and then the light stays off for about another 3,000 miles or so. Anyway, I'm not even sure this is worth mentioning because my real problem is this: A week ago I decided to check the oil before a quick 100 mile trip. I stopped at a gas station, checked the oil and it was a little low so I added a half a quart. I don't know if this is worth mentioning but I didn't have a funnel at the time, and I was very tired, very wired and I did get about a capfull or so of excess oil around the oil filler cap which proceeded to work its way down onto the engine's surface. Some of it seeped into the black plastic strip that covers the 1UZ's plugs and wires on that cylinder bank. I know from previous experience that liquids don't really leave that area too fast because the area above a spark plug is kind of like a well that, after washing your engine bay (don't do it) or spilling a little oil, will tend to sit there. Anyways, I'm digressing here. After adding a half a quart, I get in the car, try to start it, and it won't start. The engine cranks over great but will absolutely not fire. I get on the phone with a towing company for about 20 minutes, then after I get off I try the car again and it starts up. Thinking that maybe the problem had fixed itself I went on my way. I notice that the oil pressure light is off and has not come back since (even till now). Most of the night went without incident. I made the trip up, parked my car in front of a friend's house for a couple of hours. We left and went to meet up with some other people in another part of town, about a 15 minute drive. After staying over there for an hour, it was time to come home. At 3AM, with everyone on location already passed out, I get in the car, try to start it and it won't start. Same as before. Cranks over but doesn't fire. I try to catch some Zzz's out back by the pool to prepare to deal with it in the morning. It's now 6AM. Sleeping out back by a pool on a summer night in Florida, on cheap outdoor furniture really isn't fun at all. I start feeling more compassion towards homeless people. Tired, wired, and needing to be in at work in a little under 5 hours with a 1 hour ride back home, I get in aaand.. what the hell, the SC fires right up. I drive for 5 minutes and stop to fill up before getting on the highway. No problems starting up the car again to get home. I researched the issue and while I did find several references to plugs, cables, and so on, the one problem that seemed to really fit the bill was the fuel pump ECU. After doing some basic things first like checking the air filter and fuses, unplugging and replugging cables and checking vaccum hoses and so on, and still seeing the same problem (starts fine while cold / cool, will not start while warm / hot) I decided to get a fuel pump ECU. I found one on eBay from a salvage company for 90 bucks, got it shipped for the crappiest shipping ever and it just came in about 4 hours ago. So I switch it out, real easy job, took only 10 minutes.... start the car, it starts up. I smell gas while backing out of the driveway. Okay, no big deal, the engine is running rich because it needs to warm up. So far so good. I take it out for a drive, gentle at first and getting a little more aggressive as the car warms up. My goal is obviously to make sure that this really did fix the problem and to see whether or not, after driving it for a while, I can start it up again while the engine's hot. I notice that the engine is actually smoother now, or maybe I'm just imagining it? Shifts feel smoother and quicker than I remember, or maybe it was not driving my car for 5 days (and driving a loaner Saturn with no power anything, even steering, that made me have a newfound appreciation for my SC). Either way, I start having a good feeling about it, till, inevitably, I take it back home after a 15 minute drive. I have a Viper alarm on the SC that has been on there since I got it 3 years ago, and it has remote start. While the key is in the ignition, I can hit a button on the remote to keep the engine running even if I take the key out. So I do exactly that, just to let the car cool down while running instead of shutting it off abruptly. I get out of the car and sit in my garage looking at it as it's parked in the driveway, and I notice that there is faint white smoke coming out of the bottom of the car along the passenger side. I'm not sure if it was wafting backwards from the engine bay and out the side, or wafting forwards from the exhaust pipe and out the side.. but either way I kill the engine and let it sit for a few minutes. The smell isn't straight gas but it definitely has a hint of gasoline in it. I try to start the car, and it's the same issue. Cranks but won't fire. During the run with the new fuel pump ECU I had no idle issues, no jerking, no power loss, no ignition timing, or any other performance issues. There are no diagnostic lights indicating a problem. The oil pressure light doesn't come on. I am due for an oil change but since I don't feel safe getting under the car while it's on jackstands and I really don't want to chance being stuck at a Jiffy Lube for 6 hours, I wanted to know if there was something else I could check for from here before attempting the obvious. Given what I've experienced, do you think this is an electrical/electronic issue or a mechanical issue? Could something like a simple oil filter / fuel filter change fix the SC400 not starting up while the engine is hot? I had the same situation. I called a good friend who is a former Lexus Dealership Service Manager who now has his own Lexus repair business. He suggested that my injectors may be clogged and should add injector cleaner to the fuel. That's all it needed! Quote Link to comment Share on other sites More sharing options...
65electra401 Posted January 31, 2009 Share Posted January 31, 2009 I figured this out, by the way. After buying my new IS 250 I kept my SC and had some friends look at it. Believe it or not the issue is with the alternator, it's slowly failing and it won't keep the battery fully charged. The battery will have enough juice to start the SC before a long drive, after that drive there aren't enough CAs to turn the engine over quick enough. You can test this by jumping the battery with another car that's large enough. What happens when you let the car sit to "cool down" is the battery gains just enough of a charge to crank the engine and fire the cylinders.The deterioration of the alternator is still TBD. I believe it may be because the power steering pump is slowly starting to leak PS fluid on it again, which is a common problem with older SCs. I might be able to help you out there... The power steering pumps on the Sc400s are located directly above the alternators. They tend to leak right onto the alternator and ruin it. And if your power steering pump is fine, then maybe you spilled oil on the alternator when you filled up. It's a common problem on these cars. Hope i could help! Jason Quote Link to comment Share on other sites More sharing options...
65electra401 Posted January 31, 2009 Share Posted January 31, 2009 Haha, thats kind of funny... I missed the last few lines of your last post, and i basically repeated everything you just said. Sorry! haha Jason Quote Link to comment Share on other sites More sharing options...
