Rben619 Posted December 20, 2003 Posted December 20, 2003 Hey, Just got the car as an early christmas present, and tonight at a stop light i felt a slight jerk and then the 'TRACTION OFF' light went on. I had no idea the traction was on. Did i hit a button to turn it off? If so where is it? Thanks
amf1932 Posted December 20, 2003 Posted December 20, 2003 You left NO information as to the year of your car, but if it's an '02 to '04 it's located near the bottom of the dashboard near your right knee.
steviej Posted December 20, 2003 Posted December 20, 2003 Alan, refer to the title of the thread, it's a 97 ES 300. Rben, if you accidentally spin the tires too much from stand still, sometimes this will cancel out the TRAC and the off light illuminates. Turning the car on and off will reset the TRAC once the sensors cool down. However, if you accidentally hit the switch, then you need to hit the switch again. Refer to your manual. If you do not have one, register you new car with Lexus.com and they will send you one for free upon request. On my 02 ES I do not need to be at a stand still to toggle from TRAC ON to TRAC OFF. Oddly enough, my previous car needed to be at a stand still to switch back and forth. I know not what required of the 97 ES. steviej
Rben619 Posted December 21, 2003 Author Posted December 21, 2003 Thanks a lot, that does make a lot of sence, since the "Trac Off" light came on after I had accelerated at a traffic light. I registered my car at Lexus.com and ordered the manual. I did notice the "Trac Off" button on the drivers side around the knee area, and i tried pressing it to try and reverse the action but it failed to turn the light off. I did notice however that the light flashes once every time i turn the car on. Abnormal? Thanks again for the advice
