mccldwll Posted August 28, 2008 Share Posted August 28, 2008 '05 RX330 Just noticed the instrument panel lights dim, then get bright 20 seconds later, then dim again a bit later. Stopped with engine running while bright and stayed same for next minute or two until I shut off. AC was on, but I didn't hear compressor kicking on/of. Raining, and wipers were working intermittently, but I didn't notice any correlation. Had a possible battery issue last month (went dead in 30 day non use period). Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
jgr7 Posted August 28, 2008 Share Posted August 28, 2008 I would look at a bad battery connection there may have some corrosion on one or both or your battery could be on the way out. Has your clock been resetting? Jeff Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted August 29, 2008 Share Posted August 29, 2008 My guess is you have a short or some other electrical issue, any chance the car is still under warranty? Usually if you take it to the dealer and the problem doesn't "happen for them", you can video tape the issue and show them the recordings. I saw someone do that this week when i was in for service. Quote Link to comment Share on other sites More sharing options...
mccldwll Posted August 29, 2008 Author Share Posted August 29, 2008 Thanks for repliesDrove home after dark and instruments stayed bright. Problem originally spotted around 5:00 on dreary rainy day. Lights on "auto." Wondering if the lights could have been jumping between two settings? Quote Link to comment Share on other sites More sharing options...
pauljcl Posted August 31, 2008 Share Posted August 31, 2008 Thanks for repliesDrove home after dark and instruments stayed bright. Problem originally spotted around 5:00 on dreary rainy day. Lights on "auto." Wondering if the lights could have been jumping between two settings? Same thing happened to me one early morning - lights were on 'auto' and, depending on the clouds/environment brightness, the lights turned 'off' and 'on' a couple of times before deciding to stay 'off'. In that case the 'headlight' dashboard light is lit (or not) , and the cluster adjusts to the state of the lights. All was fine, and probably is with your car. Easy check is to not put the lights in 'auto' and see whether it still happens. Good luck! Quote Link to comment Share on other sites More sharing options...
