lyonsee Posted August 24, 2008 Share Posted August 24, 2008 Recently I got an issue of starting the engine. Sometime after turning on the key, the car has little response. I've checked that the battery is OK though. I need to turn off and take out the key, and turn on the key again. Turning key off and on 2 times, 3 times or more (randomly), the engine is on. Not sure the ignition switch, or starter got issue? Look like the problem is a little bit rare after I read and searched the forum. I look forward to your comments. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
hav2spool Posted August 25, 2008 Share Posted August 25, 2008 it could be a number of things it just depends on how it reacts when you try to start it clicking, just dead, ringing, buzzing, it could be a short bad connection bad starter, does it turnover at all on the first click? could be plugs, alternator, bad fuse, even a malfunction alarm system. My friends acura rl has a problem with the alarm and it defaults sometimes he has to turn the key 3 times in a row off, on for the engine to even be affected. Be specific what exactly does it do? Quote Link to comment Share on other sites More sharing options...
