bgbellji Posted December 14, 2003 Share Posted December 14, 2003 1994 LS 400. When cold I notice a noisy clunk in the front wheel well areas, when I hit a dip or bump. I have the air ride and the shocks seem to be in working order, no leaks no drop in the mornings. I only have 69,000 miles on. I had heard that it may be the front control arm. It drives great, no shakes, smooth ride and all. Funny that after it warms up and I drive it a while the noise goes away. When it's cold is when it's real noticable. Any suggestions or comments appreciated. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 14, 2003 Share Posted December 14, 2003 Sounds like worn bushings in the front struts. Quote Link to comment Share on other sites More sharing options...
BlackLex Posted December 15, 2003 Share Posted December 15, 2003 ;) It may be that the sway bar bushings need lubrication. I had some noise In front too going over speed bumps or the like. I used a silicone spray after craig on this forum suggested I use a silicone based greese. The sounds went away for me.. Goodluck! Quote Link to comment Share on other sites More sharing options...
mickg Posted December 16, 2003 Share Posted December 16, 2003 I had the same noises and creaks when cold, and sprayed the front stabilizer bushings with CRC silicone. Perfect solution. No more creaks and thumps. Mick Quote Link to comment Share on other sites More sharing options...
ThunderRiver Posted December 16, 2003 Share Posted December 16, 2003 Is there a guide with pictures and tell you how to apply silicons? My 1994 LS400 has noise too.. Is it bad if I don't address it? Quote Link to comment Share on other sites More sharing options...
mapman Posted December 16, 2003 Share Posted December 16, 2003 Have a 91 LS400 it also has clunk when i run over rough spots till i drive a few miles . I have replaced one control arm and that side does not have the noise. I think i read a service bulletin that there had been a bushing change or something on the control arm to eliminate the clunk. Quote Link to comment Share on other sites More sharing options...
