silvermate Posted December 12, 2003 Posted December 12, 2003 will the 95 and older model oem Ls400 wheels fit a 92 ls 400??
silvermate Posted January 8, 2004 Author Posted January 8, 2004 actually the specific question is will the oem rims off of a 99 ls400 fit on my 92 ls 400??
bbsal Posted January 9, 2004 Posted January 9, 2004 im going with yes.as long as the offset is the same and the lug nuts pattern is the same it will work.check and find the spec for your year and the 99 and then you will see for sure.theres a few sites to find specs like that for wheels so try a search in yahoo or goggle.i know the 95 es 300 rims will work with 98 99 so im betting its the same for your car.
SW03ES Posted January 9, 2004 Posted January 9, 2004 Yes ALL LS wheels will fit all generations of the LS.
SKperformance Posted January 9, 2004 Posted January 9, 2004 are you sure? i thought the earlier ones had a clearance issue with the front calipers?
silvermate Posted January 12, 2004 Author Posted January 12, 2004 ok. question answered i just got my rims and tires in. they are 5 spoke off of a 99 ls 400, and i mounted them on my 92 with no problem. they look great. and the car handles a lot better with the wider tires. thanks
