gregi Posted May 15, 2008 Posted May 15, 2008 Hello folks. I recently noticed the "tail light is out" sign on my dashboard. No sweat replacing the bulb at all, but the indicator light still won't go off even though the new bulb works fine. Anyone know how to reset it? Thanks!
steviej Posted May 28, 2008 Posted May 28, 2008 Hello folks. I recently noticed the "tail light is out" sign on my dashboard. No sweat replacing the bulb at all, but the indicator light still won't go off even though the new bulb works fine. Anyone know how to reset it? Thanks! there is no reset other than replacing the bulb that is out. If the indicator light is always on, then it is a tail light or signal light that is out. If the indicator light only comes on when you step on the brake, then it is one of several brake light bulbs. steviej
SW03ES Posted May 28, 2008 Posted May 28, 2008 There are a couple little wing lights in there that might be out and you just can't tell...
