Buzzing Noise Coming From Steering Wheel
johnhoward
Hello all -
Problem - faint vibration noise/rattling from my steering wheel cover area. Car - 99 LS
When I barely push my finger, or hand on the airbag cover on the wheel the vibration-noise stops...
When you have a car this quiet, everything sounds loud....
Again, this noise is faint and constant and almost sounds like a rattling, buzzing noise. It occurs only when driving all speeds, and even when inching along in traffic. I think if I remove my steering wheel cover I'll figure it out. However, I'm a bit shy on doing this (due to the airbag etc. under there).
Anyone have this happen and know how to fix it, or what the hell it is??
Thanx -
Start checking the position of the plastics in the steering wheel tighten all screws you can see. Then check for loose articles in the pockets and different areas. Check also in the back seat middle comparment area.CPR
