Hard Shifts
My '93 SC400 is starting to make some hard initial shifts when when it is started cold first thing in the morning, shifted from park into reverse to back out of the garage and then into drive. Once it even chirped the tires. It does not happen all the time, and does not seem to be associated with high engine idle rpm. After it warms up, the shifts are normal. Has anyone had this problem or does anyone have any ideas? The trans was serviced 15k miles ago. Thanks!
are you guys running the type T-II trans fluid.
the wrong fluids can cause hard shifts.
but on the other hand, i did read a technical service bulletin about dropping the valve body and adding a five ball.
i swear it. somethign about smoother shifts.
