The Pir@te Posted April 26, 2008 Share Posted April 26, 2008 I got up this mast from ebay and I got it fixed in it's place but still the wire to connect which confused me a bit so I need some help of yours up in here? here you go with the pictures, can you give me up some hints... Quote Link to comment Share on other sites More sharing options...
BD Mobile Electronics Posted April 27, 2008 Share Posted April 27, 2008 Is that was plugged into the factory antenna? Also can you tell me what the directions say about what the white and red are supposed to go to such as constant or switched may be referred to as ignition. Quote Link to comment Share on other sites More sharing options...
The Pir@te Posted April 27, 2008 Author Share Posted April 27, 2008 Is that was plugged into the factory antenna? Also can you tell me what the directions say about what the white and red are supposed to go to such as constant or switched may be referred to as ignition. Thanks for ur interest, in the last picture you can see a red and white wires on the right hand side which should be weld with the one the left hand side, any idea which one goes with which.. the one on the left hand side is the factory input to the OEM mast. i will have a look on the directions(manual) for the white and red... Quote Link to comment Share on other sites More sharing options...
