Rx350 Air Pressure Light Will Not Go Off
The low air pressure light will not go off. Have checked pressure at 34 psi. Also, the rear hatch will not automatically go up. Does anyone know if they are run through the same fuse?
This is a 2008 used car. Unfortunately, it did not have the owners manual with it.
Well, sounds like this is still under warranty. Check the air pressure in your spare tire, that usually is the cause. As for the hatch, it could be anything.
RU sure U R pushing the switch for the hatch???? AFAIK the hatch will not go up and down automatically you must use the swith behind the little closed door on the left side of the dash.
Go to the Lexus website and click on the owners tab. You can register and read the owners manual for your RX on line.
