Stoofpilot Posted April 5, 2008 Share Posted April 5, 2008 The low air pressure light will not go off. Have checked pressure at 34 psi. Also, the rear hatch will not automatically go up. Does anyone know if they are run through the same fuse? This is a 2008 used car. Unfortunately, it did not have the owners manual with it. Quote Link to comment Share on other sites More sharing options...
okay3wire Posted April 5, 2008 Share Posted April 5, 2008 The low air pressure light will not go off. Have checked pressure at 34 psi. Also, the rear hatch will not automatically go up. Does anyone know if they are run through the same fuse?This is a 2008 used car. Unfortunately, it did not have the owners manual with it. Well, sounds like this is still under warranty. Check the air pressure in your spare tire, that usually is the cause. As for the hatch, it could be anything. Quote Link to comment Share on other sites More sharing options...
skywagon Posted April 6, 2008 Share Posted April 6, 2008 The low air pressure light will not go off. Have checked pressure at 34 psi. Also, the rear hatch will not automatically go up. Does anyone know if they are run through the same fuse?This is a 2008 used car. Unfortunately, it did not have the owners manual with it. RU sure U R pushing the switch for the hatch???? AFAIK the hatch will not go up and down automatically you must use the swith behind the little closed door on the left side of the dash. Quote Link to comment Share on other sites More sharing options...
dennisk Posted April 20, 2008 Share Posted April 20, 2008 The low air pressure light will not go off. Have checked pressure at 34 psi. Also, the rear hatch will not automatically go up. Does anyone know if they are run through the same fuse?This is a 2008 used car. Unfortunately, it did not have the owners manual with it. RU sure U R pushing the switch for the hatch???? AFAIK the hatch will not go up and down automatically you must use the swith behind the little closed door on the left side of the dash. Go to the Lexus website and click on the owners tab. You can register and read the owners manual for your RX on line. Quote Link to comment Share on other sites More sharing options...
