Heated Seat Hot Spots?
DrJfrmLA
My '04 LS 430 has a hot spot in the driver's seat bottom, right side. It's still under warranty, so the stealer will have to figure it out and fix it, but I'm wondering if anybody else has had the same problem. It gets hot enough to make it really unpleasant, not just a toasty warm that you like in winter. Just that one spot. Any ideas?
I would stop using it until you get it serviced.
Do you have the heat/cool seats? If so, it is an air flow problem. These do not have elements, but rather solid state devices that do the heating or cooling depending on the voltage polarity applied, and a fan blows the heat over thm to your bod.
