95 Ls400 Codes
billhinton
Wife took car to shop in Atlanta to diagnose "check engine light". Shop said cat converter which new from dealer would over $900 for part only. They can do for under $600 installed. Mienke says 239 each installed.
Questions:
1) How can I tell if both need replacing?
2) should I do the left then the right if need be?
3) I took off gas cap and re tightened. Would that correct it if that was the problem or
4)should I put a new one on or
5) should I disconnect battery to reset to see if it comes back on?
Thanks for any and all help
Bill
  • 1 month later...
