Ls400 How To Remove Front Seat?
nfinite
I have LS400 1992 and i have a problem with a front seat.The left side rotor inside the seat went off and i can't put my seat back in position.Only right side rotor is working but it's not strong enough to lift the seat back.I'm wondering does any one had such a problem before with this car?Does any one has a tutorial how to take the seat out?
  • 3 months later...
The cover behind the seat which has the storage slot comes off by unscrewing 2 screws on the bottom end of cover. Then you will see a horizontal metal rod on the lowest area of the back. It has pulled out from its gears at the inner end. Just use pliers to push it back in. (first make sure the seat is level) You can also try using liquid weld to make sure it stays.
