nfinite Posted February 3, 2008 Report Share Posted February 3, 2008 I have LS400 1992 and i have a problem with a front seat.The left side rotor inside the seat went off and i can't put my seat back in position.Only right side rotor is working but it's not strong enough to lift the seat back.I'm wondering does any one had such a problem before with this car?Does any one has a tutorial how to take the seat out? Quote Link to comment Share on other sites More sharing options...
Bali26 Posted February 3, 2008 Report Share Posted February 3, 2008 yes search for twisting seat back. You need to remove rear cover on seat and push back a shaft which has come out of the gear. Quote Link to comment Share on other sites More sharing options...
Bali26 Posted February 3, 2008 Report Share Posted February 3, 2008 you dont need to take seat out. Quote Link to comment Share on other sites More sharing options...
kidwired Posted May 10, 2008 Report Share Posted May 10, 2008 hey same problem here. I searched this forum for "twisting seat back" and did not find anything relevant, anymore clues? Quote Link to comment Share on other sites More sharing options...
Bali26 Posted May 10, 2008 Report Share Posted May 10, 2008 The cover behind the seat which has the storage slot comes off by unscrewing 2 screws on the bottom end of cover. Then you will see a horizontal metal rod on the lowest area of the back. It has pulled out from its gears at the inner end. Just use pliers to push it back in. (first make sure the seat is level) You can also try using liquid weld to make sure it stays. Quote Link to comment Share on other sites More sharing options...
