I HAVE AN SC 400 1995, AND WOULD LIKE TO KNOW, SINCE I HAVE 18'' RIMS, MY REAR TIRES WEAR OUT ON THE INSIDE, DOES ANY ONE KNOW IF ITS THE TOE IN OR OUT, OR DO I NEED TO GET A PART?
The rear camber typically wears out on the rear suspension...Try a wheel allignment to see if the rears can be alligned properly... If not you will need to change out the bushings and what not...
