hi im working on a rear suspension of a sc300. why are the lower control arm bolts so hard to remove. there stuck. even a very strong impact gun wont remove them. is there some trick or special tool i dont have??? help!!
Try using liquid wrench or WD40...Spray the bolts generously and let is sit for a minute and torque it down... Those suspension bolts haven't been turned since the car was built, exposed to the outside elements they tend to freeze up and get stuck...
Use a breaker bar with and extension and torque, it will give...
The other problem is the bolts go through an eyelet inside the rubber bushing . So even if the bolt turns it is stuck to the eyelet and will have to be cut off to be removed.
