98 ES (low beam) headlight upgrade suggestions?
jftsai
Hi there!
I was wondering if anyone has experience upgrading the lowbeam headlamps on a 98 ES. The US spec lamps seem to be somewhat dim.
Standard bulbs are H7's. The standard fog lamps are no help either.
Anyone have any experience with upgrade bulbs such as philips visionplus or osram silverstar (eu spec)? Is there a significant difference?
Or is HID a better answer? Which kit(s) and how much?
Any comments would be most appreciated.
Thanks! :D
That was a 5500K kit... The 4500K would be my suggestion. The cutoff is still very nice because of the projectors... it isnt as defined as a OEM HID projector but it is enough so that it does not generate excessive glare.
I'll see if we can get a group buy going :) Would there be interest?
I mounted the ballast to the washer bottle and the battery tray...
Installation took less than 45 minutes... had to undo the bolts to the washer bottle to have access to the lights.
Here was the grounding point on the passenger side:
The driver side was grounded to a similar bolt, but on the front ....
