lexus53 Posted January 1, 2008 Posted January 1, 2008 I have a 93 Ls 400.Tha casette for the radio doesn't work.Is it hard to remove the radio from the dash?Would I be able to replace the radio with a OEM CD player? Thanks
1990LS400 Posted January 1, 2008 Posted January 1, 2008 Here are removal instructions: http://www.carstereohelp.com/stereoremovalLexusLS400str.htm It's probably only a 5 minute job after you have done it once or twice. If you mean that your current radio does not have a CD button, you could substitute a LS400 radio with a CD button and install a CD player -- if you can find all the parts. The local Lexus dealer here did swaps like that back in the early 90's when a customer wanted a CD player on a car that didn't have one installed at the factory. Or you could install an aftermarket radio/CD/MP3 player - even one with nav and sat radio. I've seen a number of threads over the years where someone has done something like that.
VMF Posted January 1, 2008 Posted January 1, 2008 there are brackets and harnesses available for the aftermarket stereo installations for the earlier LS models
lexus53 Posted January 4, 2008 Author Posted January 4, 2008 Here are removal instructions: http://www.carstereohelp.com/stereoremovalLexusLS400str.htmIt's probably only a 5 minute job after you have done it once or twice. If you mean that your current radio does not have a CD button, you could substitute a LS400 radio with a CD button and install a CD player -- if you can find all the parts. The local Lexus dealer here did swaps like that back in the early 90's when a customer wanted a CD player on a car that didn't have one installed at the factory. Or you could install an aftermarket radio/CD/MP3 player - even one with nav and sat radio. I've seen a number of threads over the years where someone has done something like that. Thanks very much. Photos and info is excellent.
