tiggere77 Posted December 20, 2007 Share Posted December 20, 2007 thank you guys for helpin me with my sc300 but now i took 2 codes for the car that said 25 and 26 something about air-fule running rich but does anyone know how to fix this? :cries: :cries: Quote Link to comment Share on other sites More sharing options...
tHeWiFe Posted February 22, 2008 Share Posted February 22, 2008 thank you guys for helpin me with my sc300 but now i took 2 codes for the car that said 25 and 26 something about air-fule running rich but does anyone know how to fix this?:cries::cries: First off try this: Diagnostic Code Clearance 1. After completing repairs the diagnostic code retained in memory can be cleared by removing the DOME fuse for 10 seconds or more, with the ignition switch off. 2. Check that the normal code is displayed after connecting the fuse. Some information taken from the Circuit Description with suggested troubled areas for these two codes Hope it helps. 25 Air Fuel Ratio Lean Malfunction (1) Main oxygen sensor voltage is 0.45 V or less (lean) for 90 sec. under conditions (a) and ( B ). (2 trip detection logic)*2 (a) Coolant temp.: 70°C (158°F) or more. ( B ) Engine speed: 1,500 rpm or more Troubled area for above referenced Open or short in main oxygen sensor circuit Main oxygen sensor Ignition system ECU (2)*1 Difference of air–fuel ratio feedback compensation value between front (No. 1 3 cylinders) and rear (No. 4 6 cylinders) is more than 15 percentage for 20 sec. or more under conditions (a) and ( B ). (2 trip detection logic)*2 (a) Engine speed: 2,000 rpm or more. ( B ) Coolant temp.: Between 60°C (140°F) and 95°C (203°F). Troubled are for above referenced Open and short in injector circuit. Fuel line pressure (injector leak, blockage) Mechanical system malfunction (skipping teeth of timing belt) Ignition system Compression pressure (foreign object caught in valve) Air flow meter (air intake) ECU (3)*1 Engine speed varies by more than 15 rpm over the preceding crank angle period during a period of 20 sec. or more under conditions (a) and ( B ). (2 trip detection logic)*2 (a) Engine speed: Idling ( B ) Coolant temp.: Between 60°C (140°F) and 95°C (203°F). Troubled area for above referenced Open and short in injector circuit. Fuel line pressure (injector leak, blockage) Mechanical system malfunction (skipping teeth of timing belt) Ignition system Compression pressure (foreign object caught in valve) Air flow meter (air intake) ECU 26 Air Fuel Ratio Rich Malfunction 1) Difference of air–fuel ratio feedback compensation value between front (No. 1 3 cylinders) and rear (No.4 6 cylinders) is more than 15 percentage for 20 sec. or more under conditions (a) and ( B ). (2 trip detection logic)*2 (a) Engine speed: 2,000 rpm or more. ( B ) Coolant temp.: Between 60°C (140°F) and 95°C (203°F). Troubled area for above referenced Open and short in injector circuit. Fuel line pressure (injector leak, blockage) Mechanical system malfunction (skipping teeth of timing belt) Ignition system Compression pressure (foreign object caught in valve) Air flow meter (air intake) ECU (2) Engine speed varies by more than 15 rpm over the preceding crank angle period during a period of 20 sec. or more under conditions (a) and ( B ). (2 trip detection logic)*2 (a) Engine speed: Idling ( B ) Coolant temp.: Between 60°C (140°F) and 95°C (203°F). Troubled area for above referenced Open and short in injector circuit. Fuel line pressure (injector leak, blockage) Mechanical system malfunction (skipping teeth of timing belt) Ignition system Compression pressure (foreign object caught in valve Air flow meter (air intake) ECU Quote Link to comment Share on other sites More sharing options...
