What Do Codes 25 And 26 Mean? And How To Fix It?
tiggere77
  • 2 months later...
thank you guys for helpin me with my sc300 but now i took 2 codes for the car that said 25 and 26 something about air-fule running rich but does anyone know how to fix this?:cries::cries:
First off try this:
Diagnostic Code Clearance
1. After completing repairs the diagnostic code retained in
memory can be cleared by removing the DOME fuse for 10
seconds or more, with the ignition switch off.
2. Check that the normal code is displayed after connecting the
fuse.
Some information taken from the Circuit Description
with suggested troubled areas for these two codes
Hope it helps.
25 Air Fuel Ratio Lean Malfunction
(1) Main oxygen sensor voltage is 0.45 V or
less (lean) for 90 sec. under conditions
(a) and ( B ).
(2 trip detection logic)*2
(a) Coolant temp.: 70°C (158°F)
or more.
( B ) Engine speed: 1,500 rpm or more
Troubled area for above referenced
Open or short in main oxygen sensor
circuit
Main oxygen sensor
Ignition system
ECU
(2)*1 Difference of air–fuel ratio feedback
compensation value between front (No.
1 3 cylinders) and rear (No. 4 6
cylinders) is more than 15 percentage
for 20 sec. or more under conditions (a)
and ( B ).
(a) Engine speed: 2,000 rpm or more.
( B ) Coolant temp.: Between 60°C
(140°F) and 95°C (203°F).
Troubled are for above referenced
Open and short in injector circuit.
Fuel line pressure (injector leak, blockage)
Mechanical system malfunction (skipping
teeth of timing belt)
Ignition system
Compression pressure (foreign object
caught in valve)
Air flow meter (air intake)
ECU
(3)*1 Engine speed varies by more than 15
rpm over the preceding crank angle period
during a period of 20 sec. or more under
conditions (a) and ( B ).
(a) Engine speed: Idling
Ignition system
caught in valve)
ECU
26 Air Fuel Ratio Rich Malfunction
1) Difference of air–fuel ratio feedback
compensation value between front (No. 1
3 cylinders) and rear (No.4 6 cylinders) is
more than 15 percentage for 20 sec. or
more under conditions (a) and ( B ).
Ignition system
caught in valve)
ECU
(2) Engine speed varies by more than 15
Ignition system
caught in valve
ECU
